![]() | Home > General > DRL wring help and advice |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 421 ![]() ![]() ![]() |
If you go to Powerfull UK site they have a video showing how to wire up OSRAM DRL/Fog lamp units showing connections to the multi-pin connector which plugs into the headlamp units. |
You don't have to remove the fuses and relays but you do have to undo and lift up the whiteish part off the fuse box they are fitted in to gain access to the underside and wiring.
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 ![]() ![]() |
Thanks for the info Col, question for you - when I remove the headlights do I need to disconnect the battery 1st? I remember when I fitted the AB bumper I was advised to disconnect the battery before removing lights. But in doing this I won't be able to test the pins to find the sidelight and ignition positive? Or can you get to the pins with the headlights still attached?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
No you don't need to disconnect the batt unless lifting the fuse box.
John,
