Home > Maintenance & Modifications > AB front bumper DRL's - UPDATE!!
maci234
J2D wrote:
They are exactly the ones I purchased! They were delivered today, just been out trying them out. First impressions are they are very bright, very impressed with them.
They as have a good feature of staying on for 30 seconds after you turn the engine off, and give you the option to have them at 30% or completely off when connected to the sidelights or headlights.
I am going to attempt to fit these the our 2011 plate Sport at the weekend, and from what Col has said above, I'm hoping to find an ignition live from the headlight.
Couple of questions -
Should I connect the dimming feature to the Headlights or Sidelights? (Like the idea of having the sidelights and DRL's on at the same time when starting to get dark, but not too dark)
Can I find a permanent live from any of the headlight pins?
Thanks in advance
John
keep us posted how you get on pictures too if you can
Post #505545 Thu Sep 15 2016 10:01pm
maci234
very interested too let us know how it goes fitting maybe pictures thanks
Post #505546 Thu Sep 15 2016 10:02pm
Bigbore
England 2012 Range Rover Sport SDV6 HSE Orkney Grey
Thanks in advance
John
Sidelights,also use heated seats relay for perm live. RRS SDV6 HSE Orkney Grey,Premium Ebony Black leather,MY12 Autobiography Exterior Design Pack,22"Diamond Turned Rotor Alloys,interior LED's/Number plate,boot LED's x 2,rear entertainment,HD Dash cam,ALIVE Remap,Bumper DRL's
Post #505548 Thu Sep 15 2016 10:15pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
They are the ones I have fitted to mine, matched perfectly to my eyes for brightness, appolagies for the slight blurriness.
[URL=]
[/URL]
They were originally wired to be on then switch off when side lights were turned on, but then I changed the relay so they stay on permanently and solely operate with the ignition key. Had them in for over a year now, they are constantly on and not weakened one bit. Really good bit of kit for the money.
Post #505549 Thu Sep 15 2016 10:18pm
maci234
which leds did you use ,standard bumper was fitting easy thanks
Post #505555 Thu Sep 15 2016 10:40pm
Danv8
Me? The ones in post 12.
Post #505560 Thu Sep 15 2016 10:59pm
B9BS X
Hi J2d
Did u end up fitting the DRL's as ive bought the same kit and want them on permanently on ignition.
How did u end up wiring them and do u have any pics of wiring and with lights on if fitted?
Cheers RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #507608 Tue Oct 11 2016 9:58pm
