![]() | Home > Faults & Fixes > reverse mirror dip help |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Having the same issue too, my passenger side will not dip at all when selecting reverse or when trying to adjust, will turn left and ringht but not up and down |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
Oh no I can adjust mine fine it even moves slightly when I select reverse just won't go all the way down like before. I don't know if there's any way of resetting them ? |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 ![]() ![]() ![]() |
I had a x5 that had same problem, I removed mirror glass and un screwed the mechanism that hold mirror in place and there is 2 metal contact prongs that functioned the mirror tilt, I gave them a clean with contact cleaner and bent the prongs slightly to be sure of good contact and all was good again, don't no if the sport uses the same princable but thought I'd mention it (maybe it will help) |
Got to be worth a try thanks , annoying when it won't go down all the way 😡 |
Kermit1970 Member Since: 27 Nov 2016 Location: Ayrshire Posts: 8 ![]() ![]() |
Had the same problem & fixed today. Went into settings on the stock, mpg,range etc. Press & hold & brings up a other menu changed the reverse/mirrors to auto. Mirrors now dipping. |
