Home > General > Would A Gearbox Reset Help Or Cure ...
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi, on puling away i get a shunting feeling towards the rear of the car, and every time i slow right down and accelerate the same again. If i pull over and turn off, Restart after 10 seconds it has gone and back to silky smooth Confused Please any advice on this would really help Thumbs Up Just to add 67000 miles but it is an 07, could it need a gearbox flush ?? 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #504934 Fri Sep 09 2016 4:11pm
Gornal Hills
Hi again, Have just checked the router ,make sure i'm connected Rolling with laughter Any ideas folks Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #504953 Fri Sep 09 2016 5:31pm
Bodsy
Site Sponsor
Hiya,
A gearbox reset may help for a short time, but I'd be inclined to change the gearbox oil first of it's never been changed before.
Easy to do. Either a megaflush, or drop the oil, refill (about 6/7 litres),MTL through the gears and then drop the oil again and refil again. Engine running, oil about 30-50 degrees when you out the last litre in. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #504956 Fri Sep 09 2016 6:05pm
Gornal Hills
Hi Bodsy and thanks for the reply. i did think the gearbox oil was coming to the end of its life and i did wonder if it needed changing. I will be in touch soon to sort out my EGR's and also a gearbox reset, got it back now after having someone chop the bumper off and it looks good, thanks again. 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #504969 Fri Sep 09 2016 10:10pm
Bodsy
Site Sponsor
Thumbs Up Bodsys Brake Bible
See it HERE
Post #504970 Fri Sep 09 2016 10:33pm
Disco_Mikey
Also check the rear prop mounting, very guilty for collapsing
That said, mine had a thump, and it was a worn front prop Confused
Post #504981 Sat Sep 10 2016 7:35am
Gornal Hills
Hi Mikey, thanks for the reply, its fine over 20mph but when below it feels like the prop (rear) has 1 bolt left to undo Big Cry 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #504997 Sat Sep 10 2016 10:24am
Disco_Mikey
As did mine Thumbs Up
Post #505015 Sat Sep 10 2016 2:35pm
Gornal Hills
Thanks again for the advice Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #505016 Sat Sep 10 2016 2:50pm
Gornal Hills
Ok folks, done it again today. Pulled away and thought the prop shaft was loose, no oil in the rear diff, clunking symptom up to 15 MPH. I stopped, turned off for 10 seconds and restarted, smooth as silk thereafter. No sticking EPB or rear pads and its not a misfire, Do i need a gearbox reset ??? Every time i restart it has gone altogether Confused 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #505640 Fri Sep 16 2016 10:12pm
Lost for Words
Transfer box clutch calibraton? Visiting from DISCO3.CO.UK
Post #505685 Sat Sep 17 2016 11:28am
Gornal Hills
Hi LFW, and thanks for the reply, in simple terms to a Locksmith is this easy to do...and how Thumbs Up I did think it was mechanical at first but turning on and off never repaired prop shafts, bearings or the diff in my book,that's why i was wondering about a gearbox reset or hard reset ... Confused 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #505699 Sat Sep 17 2016 2:16pm
Lost for Words
You can try this...
Quote:
. Switch ignition to position II without the engine running
. Select automatic or manual transmission neutral
. Depress the throttle pedal fully
. Press and hold the range change switch for 5 or more seconds to allow calibration to start
. When the calibration is heard to start, the switch and throttle pedal can be released
. Upon adopting high range, start the engine and wait 30 seconds while the first calibration of the clutch in high
range is done. While this calibration process is in progress, no shifting is accepted
. Switch ignition off and wait 15 seconds
. Start engine
. Perform a range change to low range. Wait 30 seconds while the first calibration of the clutch in low range is done.
. Range and clutch calibration is now complete.
...but it seems it doesn't work on all vehicles, in which case you need a diagnostic tool - just a 5 minute routine. Thumbs Up Visiting from DISCO3.CO.UK
Post #505701 Sat Sep 17 2016 6:00pm
Gornal Hills
Hi LFW, thanks again bud i'll try it later on today Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #505759 Sun Sep 18 2016 11:59am
Gornal Hills
Ok folks, had the prop checked today and all fine. It drove to the garage like a bag of K******s, turned off for 5 mins, started up and perfect again..... Please, Please, Please any ideas would be welcome Thumbs Up (does it sound like the Torque Convertor) Big Cry 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #505992 Wed Sep 21 2016 11:45am
