![]() | Home > General > Changing Tyres/ Removing Wheels |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
I've never heard of an airbag going off from jacking the car up. There are sensors to detect a sudden deceleration or acceleration to trigger airbag inflation and you'd have to be extremely vigourous and speedy in your jacking to trigger one. I believe it's best to raise the car to 'off road' height to lessen the jacking as the car will try to level itself out from normal height, but others have said it doesn't matter that much. The car will soon sort itself out afterwards. I'm in the shed, I'll be back in the real world in a minute.
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
The Wheel repair guy needs to stop listening to his mates down the pub, the correct jacking procedure is in your handbook 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5113 ![]() ![]() ![]() |
I'm inclined to think he was talking of dislodging a Air Suspension Airbag not the Crash One's, even so it is still crap taking in to account you see these vehicles off road with one wheel hanging in the Air.
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
Correct me if im wrong, but locking at access only increase the speed limit to about 20mph.
The guy was talking a load of bull you can jack the car at any hight. If your at home using a trolley Jack then you need to jack under the sus arms not the chassis as you'll hit the jack max and the wheels will still be on the ground. When I use a 2 poster ramp I put the car into off road height if you leave it in normal the cars tend to drop down onto the bump stops but in off road there locked. 2008 G4 RRSport TDV8 current
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 ![]() ![]() ![]() |
All much appreciated advice. Will set to off road and put jack under suspension arm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2015 ![]() ![]() |
No need if using suspension arm just leave it in normal height.... * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
