![]() | Home > Technical > replacing suspension compressor |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
I think there's a full description in " How To "
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2018 ![]() ![]() |
AMK ones are an up rated version * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Had old type taken off mine and AMK fitted. no issues. |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
I got a refurbed kit from ebay, all done in a day, no problem at all, however you will never get the air pipes off, so you will need to cut them, just make sure sure you buy a 8 and 10mm connector before you do the job 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
monkswood Member Since: 24 Aug 2016 Location: newcastle Posts: 14 ![]() ![]() ![]() |
That's great thanks for the feedback, I can see what like tee piece connectors and another electrical connection, possibly a pressure sensor, do these also come out with the compressor |
from what I can remember, there are two electrical connectors that need to be unplugged, one small air pipe that will come out, there will be a bit of pressure in it, and at the other end two big air pipes, not under pressure, by all means try and get them out, but these are the ones too cut off, leaving a good few inches to connect the connectors too.
Ok cool I'm attempting this tomorrow thanks again all |
Coxylad Member Since: 11 Jul 2013 Location: Preston Posts: 48 ![]() ![]() ![]() |
I was given a old one from a garage so got a kit from ebay and refurbed that one and replaced the one on my car works great 2 weeks in and no problems.
