| RRSPORT.CO.UK | ||
|  | Home > Technical > Wobble |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | I had this on mine, cured by new bushes and a steering rack.  The beauty of Land Rover Warranty
|  Wed Aug 31 2016 6:59am |
| Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157      | What's the approximate cost of a new rack? I have a good warranty, but unless the part has failed I suspect I will need to cough up for it (assuming that's the problem)... 2010 TDV8 | ||
|  Thu Sep 01 2016 6:08am |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | I think my Warranty bill was circa €3k In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
|  Thu Sep 01 2016 6:27am |
| Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157      | I'll see what I can do. For that money, I may live with the wobble! 2010 TDV8 | ||
|  Thu Sep 01 2016 6:30am |
 So IF it failed the MOT then I Guess it would be covered. But first of all check all the wishbone bushes etc. The simple test I did on mine, have the car rolling along circa 5 MPH and jab the brake pedal on and off fiercely (short hard jabs) if you can hear any clonk or clang, then check all the bushes prior to going down the rack route.   Best done with the radio off and without the Wife in the Car  In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. | ||
|  Thu Sep 01 2016 6:33am |
| Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157      | Thanks mate. Is in with Rovertune for a look in a week or so. I'll see what they say, but you are right that the best scenario would be to fail the mot as I have cover.... 2010 TDV8 | ||
|  Thu Sep 01 2016 6:35am |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025    | Rob at Rovertune will know what's causing it   | ||
|  Thu Sep 01 2016 9:08am |
| Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157      | I will indeed. Was looked at before by both him and Newbury 4*4 and neither could diagnose as all looked OK, nothing loose etc. Having said that, I was questioning my air suspension at the time too. Now that appears to have been resolved with a hunter alignment and suspension recalibration it only leaves this issue which may help, so let's see.
|  Thu Sep 01 2016 10:13am |
| Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157      | In with rovertune today. They don't know what it is. Apparently my front discs (recently replaced with pads) were very hot. Also they said they couldn't rotate the wheels freely when up on ramp. The new discs and pads I have are apparently aftermarket (fitted by Newbury 4*4).
|  Mon Sep 12 2016 5:53pm |
| Down&Dirty Member Since: 31 Dec 2015 Location: Somewhere out back Posts: 92    | Warped disks?
|  Mon Sep 12 2016 6:39pm |
| Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157      | My thought too, but less than 2k miles? The ones before were warped too but were genuine. Could that be indicative of another issue?if it is warped discs I guess I need to foot the bill as let them fit aftermarket ones (not that I knew, I assumed Newb 4*4 used genuine parts)....
|  Mon Sep 12 2016 6:47pm |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025    | Hope it gets sorted soon   | ||
|  Tue Sep 13 2016 8:52am |
| Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157      | On way to pick up. New (proper) pads and discs and a good clean of various bits filled with grease. Will report back, but am so used to being disappointed and problem still being there that I darent get any hopes up! 2010 TDV8 | ||
|  Tue Sep 13 2016 5:37pm |
| Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157      | Just got back. Much better. No wobble on light braking and much less vibration on acceleration. So all in all, expensive but worth it.
|  Tue Sep 13 2016 6:57pm |
| Posting Rules
