![]() | Home > Technical > ARB/Bottom Arm Bush replacement |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003
Dynamic response or ACE as you call it is standard on TDV8 an d S/C not on the TDV6 though pos as an optional extra, look under the bonnet and see if there is a res near the radiator othrt than the PAS res.
| kttlaweb Member Since: 08 Aug 2016 Location: Derbyshire Posts: 16
Thanks for the reply and the welcome Camelrock.
Yes ACE was on D2's the other way to check is to look under the o/s you will see a valve block fastened to the outer chassis rail with pipes going for and aft. 2008 G4 RRSport TDV8 current
