Home > Maintenance & Modifications > The sweet smell of sweaty trainers! Please help!
Phil B
Hi Guys
I run a summer 2012 HSE and in recent times it has become a little unpleasant to be in. In place of the cosy smell of high grade hide, I enjoy a smell I can only describe as cat pee, or sweaty trainers. Does anyone have an idea what might be causing this? We haven't spilt anything in the car. I'm wondering if it's something going on in the AC/heating system.
Thanks in advance. In the meantime I'll continue using the cotton wool up the nose;)
Phil
Post #503489 Tue Aug 23 2016 5:08pm
drdelrrs
Mold in heat/AC exchange matrix.
Post #503490 Tue Aug 23 2016 5:14pm
Paddi
Correct. All you need is what is generally known as an 'air con bomb'. Many different brands and probably all pretty similar.
Think I used a Comma branded one last time and it seemed to do the job. It is really just an aerosol that you set off in the car with the air con running and the recycle button pressed; leave it for 15 minutes - job done. 2008 MY Java Black TDV8 HSE
Post #503494 Tue Aug 23 2016 5:30pm
Johnski
As said above, these are even available from Halfords if you require an easy source. John
Post #503503 Tue Aug 23 2016 6:43pm
Phil B
Thanks guys. Will give it a go
Post #503595 Wed Aug 24 2016 12:24pm
DrRob
Keep us posted. I'm intrigued Whistle * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #503708 Thu Aug 25 2016 6:31pm
