Home > Maintenance & Modifications > Another "clunking" thread!
Deefur
Scotland 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Strange one this, hopefully you guys can help me out. I'm getting a clunk whenever I'm cornering. Low speed cornering is fine even at full lock. It seems to be a weight transference issue, whenever the weight moves from one side to the other - clunk! going over bumps is fine, no clunk so I think the suspension is fine.
Anyone experienced this?
Post #503678 Thu Aug 25 2016 1:03pm
Deefur
I should add the noise isn't from one side it seems to be coming from which ever side the weight moves from, left or right, front or rear!!
Post #503679 Thu Aug 25 2016 1:12pm
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
I'm sure someone more qualified will be along shortly, but to me it sounds as if some of the weights/ resonators(I think) hanging from the Sport are loose.
I know two are located at the rear near the exhaust tips, not sure if there are some located at the front, but, I seem to recollect there are....
Probably completely wrong, but, this spring to mind.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #503685 Thu Aug 25 2016 4:22pm
Paddi
Worn loose or broken droplinks?
Is the spare wheel winched up firmly into its home? 2008 MY Java Black TDV8 HSE
Post #503688 Thu Aug 25 2016 4:39pm
Deefur
The drop links were the first thing I had checked but the garage said they're absolutely fine!!
Post #503694 Thu Aug 25 2016 5:20pm
