Home > General > Underbonnet Liner Sag Fixing
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
The underbonnet lining on my 2010 TDV8 sags qyite a bit at the back (closest to the windscreen) as it is only held in by 3 slots in the bonnet metal rather than plastic clips like the rest of the liner. Pushing the liner back into the 3 slots does not work as it only comes back out of the slots straight away as the liner is not rigid enough to stay in place.
I am about to line the underside of the bonnet with Dynamat Hoodliner which sticks to the underside metal of the bonnet and would like to fix the sag of the original compressed felt material before I install the Dynamat Hoodliner.
Any ideas.
Post #503066 Wed Aug 17 2016 3:18pm
Easy enough do what I did.
Post #503069 Wed Aug 17 2016 3:54pm
So what did you do ?
Drill holes in the metal ?
What clips are they ? Used elsewhere on the RRS ?
Post #503083 Wed Aug 17 2016 6:11pm
They are just some push in fir trees I found in the garage, just drilled hole and pushed them in job done.
Post #503087 Wed Aug 17 2016 6:24pm
