Home > Faults & Fixes > Front suspension won't rise
Edmundz1
Hi Guys, I have searched for my exact fault on the forum but still haven't come up with much luck so I was wondering if anyone could possibly help?
I've got a 2007 v6, the car was driving fine and then suddenly the front suspension of he car just dropped to its lowest level and my ride hide indicators were all over the place. Turned he car on and off again but only the back of the car will raise and i can't drive it over 30mph. I've taken it to a Land Rover specialist and they have plugged the car in and tested each air bag to inflate it and also replaced my ride heights sensors on the front, that failed to work so they then tried a test compressor on the car but still having the same issue as the front won't raise. I've been told there's also no fault codes coming up either which doesn't help.
I don't suppose anyone can shed some light on this particular fault?
Thanks
Post #502338 Sun Aug 07 2016 11:45am
DrRob
Valve block on front needing a clean out?
Do a search on here and see if you find anything..... Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #502349 Sun Aug 07 2016 2:41pm
Edmundz1
That's great thanks!
Post #510611 Wed Nov 23 2016 9:15pm
Edmundz1
Oh sorry I forgot to write it ended up being the ride height sensor that had come loose from the chassis!
Post #510612 Wed Nov 23 2016 9:16pm
