| RRSPORT.CO.UK | ||
|  | Home > Faults & Fixes > TDV6 2007 faults, all sorts. Randomly sticks it in limp mode |
| ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422      | How is your  battery  alternator working ok ?
|  Fri Aug 05 2016 2:16pm |
| Garwaybeast Member Since: 29 Apr 2016 Location: Hereford Posts: 9      | Hi, not sure about the alternator. How would I check that? what problems would a bad alternator cause. As for the exhaust it doesn't kick out black smoke anymore since the exhaust was changed. The problem now lies in their being a hole in the exhaust that causes a whistling noise. | ||
|  Fri Aug 05 2016 3:01pm |
| benjack Member Since: 12 Jul 2015 Location: gwent Posts: 3    | hi I had a gearbox service 4 months ago, had a oil leak which I took it back 3 times in the end I found the leak myself only sump plug,had I slight slip in second gear they said they could not find any thing wrong. took it to promac in Cardiff ,for a oil flush and reset on Wednesday left it with them for 1 hour and now perfect. | ||
|  Fri Aug 05 2016 4:58pm |
 Low battery power can give you lots of faults that are just because there's a lack of voltage Try a local auto electrician and see if they can test your alternator output If you do a search on Here it will tell you what the correct readings are meant to be and what to turn on and off to see voltage drops 61 AB 5.0 supercharged rocket 07 HSE TDV8 with lots of toys EGR removed BAS remap 56 HSE WAS FULL OF PROBLEMS | ||
|  Fri Aug 05 2016 6:15pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      |
 For a start, there is no fluid in the ride height system. Sounds like you have dynamic anti roll bars. If it's losing fluid then it's leaking. Get that sorted because a failing anti roll bar will cause some other issues if the stability system gets confused. This might be why your brakes apply. The knocking noise needs more info. Is it at low speed when turning or something else? A ticking noise at low speed with lick applied points to the CV joint. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed | ||
|  Fri Aug 05 2016 7:21pm |
| Garwaybeast Member Since: 29 Apr 2016 Location: Hereford Posts: 9      | The mechanic failed to find a leak and put some sort of conditioning treatment in to help with the seals apparently. That was what he said the first time I took it to him. The second time he said it could be a ram?? Leaking. And that that part would need replacing? What ram?  The third time he said he re calibrated something.  Either way the reservoir still needs topping up often and the fault still occurs, but what you are saying makes sense.
|  Fri Aug 05 2016 8:14pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | The anti roll bars are effectively a hydraulic ram connecting the two ends of the bar. They sometimes leak. If it is leaking from the ram part then you need a new bar. That'll be £1200-1500...  | ||
|  Fri Aug 05 2016 8:47pm |
| Garwaybeast Member Since: 29 Apr 2016 Location: Hereford Posts: 9      | Cheers for the advice. Is there a treatment I could put into the fluid reservoir that might help the seals or stop the leak? Similar to what you can put into the power steering reservoir?
|  Fri Aug 05 2016 9:08pm |
| Posting Rules
