Home > General > Rear wheels
Gunnerboy
England 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Rear wheels
I've had a new air suspension compressor fitted about 11 months ago and I fitted new rear lower wish bones at about the same time (crappy job) and had four wheel alignment done ice noticed that the rear height now seems higher and the rear wheels look like their towing in and maybe the rides a bit harsher any clues or am I imagining it!
Post #502208 Thu Aug 04 2016 9:16pm
Measure height from wheel Center to arch.
Calibrate height.
Post #502213 Thu Aug 04 2016 10:47pm
Gunnerboy
I've measured where you said the height on flat ground in my car is 19 inches and another car I measured was 17 1/2 inches
Post #502395 Mon Aug 08 2016 2:49pm
A little high should be 465mm + or - 13mm or 18.3 inches + or - 1/2 inch.
Post #502403 Mon Aug 08 2016 3:30pm
Gunnerboy
Do I have to take it to garage to get it reset
Post #502418 Mon Aug 08 2016 6:33pm
You need a diagnostic tool such as an IDD IID BT £400
take some measurements, do some calcs, put the numbers in. Frig it a bit.
Post #502443 Tue Aug 09 2016 12:07pm
