Buckster
Here you go Jock
https://www.bobswatches.com/rolex-blog/rol...r-now.html
If it looks like this with the two lines of writing in red then I suggest you insure for a very tidy sum of money as they are very sort after by collectors. If it used to look like that but when you once had it serviced, they may have changed the dial to one with white writing as so often happened then it's not so sort after. The double red is a lot of collectors grail watch if you will.
Either way a 1977 Sea Dweller is a beautiful vintage piece and I'm sure it will continue to give many years of service 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Tue Jul 26 2016 8:03pm |
