![]() | Home > General (L494) > Noise from Pillar |
AJ1 Member Since: 06 Apr 2016 Location: Sunshine Coast Posts: 64 ![]() ![]() |
Well that all depends on your interpretation of the word "noise". Is it a squeak, rumble, knock, continuous or intermittent ?
Lyonhead Member Since: 21 May 2016 Location: Cardiff Posts: 351 ![]() ![]() |
Yes, I have a "noise " coming from there also. The car is in with the dealership now. It's like a very light metallic tapping sound but not continuous, intermittent and very distracting as its right by the side of your right ear as your driving.
The dealer won't find the fault. I have the fix. It bugged me so much I stripped everything down and found it. Let me know how you get on with the stealer and if you need help. MY 14.5 SE SDV6 Loire Blue. Silver roof. 22's. |
AJ1, I would appreciate if you could just let us know how you got rid of this in case, as you say, the dealer won't be able to find it..... Every little helps. |
Good man, thanks for that. ( pics didn't come through though).
Just got pics, thanks very much |
rangiejools Member Since: 11 May 2008 Location: Mornington Peninsula Vic Posts: 184 ![]() ![]() |
Thanks Andy, I'll be trying that fix too....got the same ticking sound sometimes.
Let us know how you go with it Jools, glad to be of help.
Andy, just got my car back from dealership and your fix did not sort the noise out |
You're welcome Lyonhead.
scott2k21 Member Since: 12 Sep 2012 Location: Aberdeen Posts: 9 ![]() ![]() |
Was this a kind of creaking noise that seemed to come with body flex (not necessarily bumpy roads giving a rattle) ...and worse on warmer days??
Not really Scott, more so a "ticking" whether the car was moving or not. However you're correct with warmer days which tells me it's 100% expansion. Also mine was on the drivers side (could still be the same part).
BlackGT3 Member Since: 23 Aug 2013 Location: Yorkshire Posts: 46 ![]() ![]() |
We had a rattle noise coming from both side by the upper front seat belt mounting. This was supposed to be fixed during last years service however, the rattle returned. Dealer (Farnell Guiseley) told me that LR had issued a new part which fixes the problem. This was ordered and fitted and the rattle has been fixed. Current:
