![]() | Home > Maintenance & Modifications > RRS 3.0 2010 Cambelt Change |
chufski Member Since: 18 May 2016 Location: Bromsgrove Posts: 13 ![]() ![]() ![]() |
two ways at looking at that I suppose.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4501 ![]() ![]() ![]() |
It is much more labour intensive than the 2.7 in any case. I expect the price of the 3.0 will increase after they have done a few |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
The belt at the front, external to the engine that drives the engine driven fan, power steering pump, air compressor and alternator. (in old terms - the fan belt) The work described on your link has only Cam belt at the front and High Pressure Fuel Pump at the rear and all their associated tensioners etc. As Disco Mikey has alluded to, the serpentine belt and its associated bits and pieces need to be removed and reinstalled as part of the cam belt job so labour is already covered but you will need to pay for these new parts which should be replaced at the same time - not all that expensive. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Baz0195 Member Since: 29 Jun 2018 Location: Telford Posts: 23 ![]() ![]() ![]() |
Hi chufski.
Try Alltrack 4x4 in Malvern. They don't lift the body for belts |
And FYI, we dont lift the body either. Perfectly doable with the body in situ, and managed to get the price down to £675 Inc VAT |
Thanks mate |
Water pump is driven off the Aux belt, so no major dramas or replicating work if it did need done in the future |
Ok cheers mikey |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 ![]() ![]() ![]() |
whats the deal with the rear belt on the 3.0?
