![]() | Home > Technical > can anyone answer this ...... |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4502 ![]() ![]() ![]() |
And at what position did you align the trigger wheel in the crankshaft?
nosmokenopoke Member Since: 09 Jul 2016 Location: Gloucestershire South West Posts: 44 ![]() ![]() ![]() |
Yes, and at what position was the crankshaft in when the ring was fitted |
Hi Mike
I do believe you have the trigger wheel approx 180 degrees out |
Mike do u have the tool ? If so am I 180 degrees out being the perfect degrees ? If yes then I would take the gamble on doing it again but without the tool. Paying 200 odd quid for a piece of metal seems a little steep.
I don't have the tool. From what I have seen, it sounds as though your trigger wheel is APPROX 180 degrees out.
