| RRSPORT.CO.UK | ||
|  | Home > Technical > HDC Fault, Transmission Fault, Special Programs Not Availabl |
| SH0X Member Since: 25 Jan 2016 Location: London Posts: 82      | Im fairly confident you have the same issue as me.
|  Sat Jul 02 2016 6:10pm |
| Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296      | Problem still not solved, Last week the fault went then 1/2 mile down the road it has re appeared.
|  Tue Jul 05 2016 11:26am |
| TDV888 Member Since: 29 Jun 2016 Location: London Posts: 11      | Update:
|  Thu Jul 07 2016 2:14pm |
| TDV888 Member Since: 29 Jun 2016 Location: London Posts: 11      | After taking the rear wheel off and having the car in the air now the 4x4 screen shows the wheels turned all the way to the right even though they are straight.....!!! Can't even recalibrate the steering as I have all these faults still | ||
|  Thu Jul 07 2016 2:20pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | This is a bit of a long shot but I can recall there was a post on Disco 3 site about someone having the steering column sensor unit come adrift from the steering column. IIRC they fixed by aralditing it back on (!).
|  Thu Jul 07 2016 3:45pm |
| TDV888 Member Since: 29 Jun 2016 Location: London Posts: 11      | Had the steering recalibrated today so that's sorted but it seems that there may be a break in the wire somewhere to the rear right abs sensor as its not recognising the new sensor (no cumminication) booked in on Tuesday but due to drive to Newcastle on Wednesday its a race against time now to get it fixed haha | ||
|  Fri Jul 08 2016 1:40pm |
| TDV888 Member Since: 29 Jun 2016 Location: London Posts: 11      | After all that headache it resulted in being a broken wire o/s/r from the abs sensor to the chassis harness it fixed all problems while the car was there also had then replace the compressor for the suspension and some new stop tail bulbs but £1500 later I have no warning lights horay!!! | ||
|  Wed Jul 13 2016 8:15am |
| SH0X Member Since: 25 Jan 2016 Location: London Posts: 82      | Glad you got it sorted.
|  Thu Jul 14 2016 11:59am |
| TDV888 Member Since: 29 Jun 2016 Location: London Posts: 11      | I used giggle pin 4x4 in Kent I deffo recommend them, I have a intermittent transmission fault that comes up which disables the hdc but I can just turn the car off then on again and it goes away, they said it's the brake pedal switch which Land Rover are having problems with as I already Changed it so if it comes back I will try the original for a while.
|  Sat Jul 16 2016 11:23pm |
| Posting Rules
