Home > Technical > Fault code
Gilly1
Fault code
hi, I have code B0001-1B(2C)
Been doing some reading and it could be few things, wiring under seats, seat belt tensioner, airbag wiring, clock spring,
I have checked/unplugged & re connected wiring under seats, checked air bag wires, removed clock spring replaced it all and still get the code but we're it previously stayed on it now goes out whenever car ignition is turned of and on again. I'm thinking in the direction of clock spring first but thought I'd ask if anyone knows any different.
Also is there a list for fault codes, to explain What code is what fault.
Post #500264 Wed Jul 06 2016 3:49pm
B0001-1B
Driver Frontal Stage 1
Deployment Control -
Circuit resistance above
threshold
NOTE: Circuit reference DR
AIRBAG F1 / DR AIRBAG R1
Driver airbag (stage 1)
high circuit resistance
Refer to the electrical circuit diagrams and check the driver airbag (stage 1) circuit for high resistance or
open circuit
Test for intermittent open circuit, high resistance faults within the clockspring by rotating the steering
column during the tests
Post #500265 Wed Jul 06 2016 3:53pm
Gilly1
Hi col, thanks for that, Thumbs Up it seems a bit to much for me I'm not great with electrics and multimeters, unless there is a dummy's guide or video I think I'm going to have to get a auto electrician on it. Sad
Post #500268 Wed Jul 06 2016 4:28pm
Gilly1
Iv also got interior lamp 1 circuit. B1D13-15. I'm thinking as the car came with led bulbs inside they are probably not canbus free and generating that code.
Post #500275 Wed Jul 06 2016 6:15pm
interior lamp 1 circuit is the front roof light and the boot light
Post #500281 Wed Jul 06 2016 8:35pm
B1D13-15 Interior Lights Circuit
"A" - Circuit short to
battery or open
Circuit short circuit to power
or open circuit
• NOTE: This DTC may be logged under normal operating
conditions. No action required if function is correct
circuit.
Not really much help, according to Note may just log fault as it has nothing better to do. Laughing
Post #500288 Wed Jul 06 2016 9:35pm
Gilly1
I'm just going to purchase a new clock spring, Iv found BRITPARTS OEM is that suitable, or is it recommended to go LAND ROVER OEM,
Post #500310 Thu Jul 07 2016 10:42am
Personally I give S**tparts a wide berth.
Post #500324 Thu Jul 07 2016 2:18pm
Gilly1
That speaks volumes mate, Thumbs Up yes I ordered genuine Land Rover part from island 4x4, don't like to be negative but let's hope it is genuine part. Exclamation
Post #500327 Thu Jul 07 2016 2:23pm
