![]() | Home > General > swaying while driving on uneven road surface |
Welcome to the forum Mark, I hope the following isn't too much bad news...........
marka Member Since: 06 Jul 2016 Location: weybridge Posts: 6 ![]() ![]() ![]() |
Hi Tim
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
Before changing steering rack I would get tie rod ends checked
Thanks Alpaca, will do |
m3virus Member Since: 18 Sep 2013 Location: birmingham Posts: 36 ![]() ![]() ![]() |
Check your tyre pressure or could need tracking👍 Current 55 reg 2.7tdvs with Hst extras |
Thanks
Also check the ride heights. From the centre of the wheel to the wheel arch directly above it should be 466 rear and 465 front or thereabouts. |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
You say you just brought it, was it private or from a dealer?
Double post... |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Are the Lower arms ok 61 AB 5.0 supercharged rocket
It was a private sale, the chap did say he had lowered the suspension by 30mm , would this make a difference ? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
Almost certainly, especially if he didn't get the alignment sorted out too. Even with the alignment done it'll probably still be bad.
Thanks for all the info evryone, this is a great forum |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
Resurrecting an old post as I’ve got a steering wander issue. Obviously I’ve had the alignment checked - it’s currently being looked at for the third time after having it up in the air to check all bushes and joints, which are tight.
