![]() | Home > Technical > Does battery need replacing |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Didn't you mention in previous posts that you were also getting the 'HDC fault system not available' . This is often the first indication of a battery that is failing or needs recharging.
| Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118
Thank-you. The joys of owning a RRS. |
| CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170
Just adding to this thread.
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
In my other thread I have been going through this - faults - starts OK after a glow plug cycle - hard to start otherwise - sometimes the trip meter resetting - yesterday doors locked and unlocked by themselves during start.
Thanks for the reply. Just looking at the best battery for amps and cost. |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
This: https://www.tayna.co.uk/EA1000-Exide-Premi...P7488.html "D2BOYS" gets you a few extra quid off. |
Thanks for that. I will call them this afternoon. 😉 |
Ordered new battery from tanya batteries and mentioned D2BOYS and got 70p discount. Fitting tonight. Let's hope it sorts the satnav and radio problems out. |
Fitted new battery. Satnav and radio still play up. What's next???? Must be battery drain somewhere. When I fitted the battery there was a spark so something is always running. Any ideas. |
You could try that other forum favourite of a hard reset ? Disconnect both leads from battery and connect them together for 30 seconds or so using e.g. a jump lead.
This sounds like the problem I'm having.
Still playing up. I have bridged the bonnet switch and locked the car. Heavy duty charger charging battery. But it will not drop below 1.3 amp. If I remove the charger and use a smart charger the volts drop within a minute or so.must have a drain somewhere. Also noticed if I use back and front heated screens with the program button, when I switch off front screen the radio go off for second. The car starts first time every morning but as soon as I rev it the satnav screen goes on and off for a good 30 seconds and radio goes on and off. Also sometimes when I press brake pedal it won't release the gear selector.
Car must have gone to sleep as smart charger is holding the voltage. |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407
I am not sure what year your vehicle is, but the early ones with seperate CD player with disc for Sat Nav, have been known to cause problems, due to not turning off properly, so still on all the time which drains battery causing all sorts of gremlins.
