![]() | Home > Technical > Dropping Suspension |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
I appreciate the issues we can have with our suspension can start to drop overnight.
I would assume so - you should always check tyre pressures when they are cold as warm tyres can be be quite a few PSI higher than cold tyres with the same amount of air in them.
| SH0X Member Since: 25 Jan 2016 Location: London Posts: 82
Do you have any air leaks from the compressor - does it go up and down ok - no over run?
Thanks for that check list - there are no adverse indications anywhere.
I have replaced the battery in my car as the old one was just about dead - since then I have not had a suspension drop but it is early days.
| All times are GMT |
