| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > turbo vanes stuck |
| brgjohn Member Since: 27 Apr 2016 Location: somerset Posts: 7      |
 i have what appears to be a situation with my turbo vanes stuck after the car (v6 diesel 2005) stood around for some time.
|  Tue Jun 28 2016 2:30pm |
| erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 153    | What about using Seafoam Deep Creep?
|  Tue Jun 28 2016 3:28pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | The vanes or the actuator ? | ||
|  Tue Jun 28 2016 4:18pm |
| brgjohn Member Since: 27 Apr 2016 Location: somerset Posts: 7      | hard to tell, but no turbo boost | ||
|  Tue Jun 28 2016 9:25pm |
| brgjohn Member Since: 27 Apr 2016 Location: somerset Posts: 7      | serious lack of acceleration, my code reader won't access the RRS, so ran along to my local garage who accessed a turbo fault code (didn't write down which one ) .I'm very conversent with the old style of turbo ,but these moving vane type are new to me! Garage man said very common failure ,although research suggests they are not worn but stuck, so , i'm trying to find a way of unsticking them ! | ||
|  Wed Jun 29 2016 12:55pm |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | Did it go go back to normal after the codes where cleared ? Or is it a hard fault (won't clear ). If turbo some people have had some success lubbing and working the actuator rod, you can get to it by removing the heat shields in the wheel arch n/s. If that doesn't work then it will prob need a new turbo.. 2008 G4 RRSport TDV8 current
|  Wed Jun 29 2016 2:05pm |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | Suggest you drop Steve Norman a PM and book a visit: http://www.rrsport.co.uk/forum/member-stevenorman.html Top guy all round and a the biggest expert you'll find.
|  Wed Jun 29 2016 2:12pm |
| brgjohn Member Since: 27 Apr 2016 Location: somerset Posts: 7      | I've removed the heatshields under the wing, the actuator appears to be engine side of the turbo and not visable.
|  Wed Jun 29 2016 8:43pm |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | You need to make a hook out of a coat hanger or welding wire and hook it over the rod then work it back and forth. It should move freely, spray with penitrating oil.. 2008 G4 RRSport TDV8 current
|  Wed Jun 29 2016 10:19pm |
| brgjohn Member Since: 27 Apr 2016 Location: somerset Posts: 7      | thanks guys, i'll go and have a word with Steve Norman | ||
|  Thu Jun 30 2016 4:22pm |
| brgjohn Member Since: 27 Apr 2016 Location: somerset Posts: 7      | long time in coming back, but with the bit of wire and a lot of lubrication the rod freed off and i now get turbo boost and no fault code. It does have however a huge flat spot when accelerating up hill .Flat to the floor fine ! is this normal for the v6 ? | ||
|  Wed Oct 19 2016 5:35pm |
| Posting Rules
