Home > General (L494) > Tyre wear in sawtooth pattern (Feathering )
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
My RRS had a slight pull towards left and dealer adjusted the wheel alignment and swapped the rear tyres to front as the original front tyres had its outer edge warn in a saw tooth pattern. After around 2000 miles I I've noticed that same on the front tyres again so showed it to the technician while getting the AD blue top-up. After test drive and checking the tyres he is saying that its normal wear, when I run my fingers I can feel the sawtooth pattern and I never had a similar with my previous cars. Inner edge of the tyres don't have this pattern , only the outside edge.
Is it normal on L494, could someone please check, I have done 11000 miles on these tyres now.
Post #499626 Mon Jun 27 2016 3:09pm
Tim in Scotland
I have 22" wheels and my tyres are hardly worn at all at 12000 miles, certainly no uneven tread wear patterns. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #499627 Mon Jun 27 2016 3:18pm
DaveW
Just make sure your pressures are correct in the first place. After that, get the dealer to confirm your geometry is correct.
We do see this on test cars when we're leaning on the tyres a bit trackside but not too often on the road.
If you're still seeing it after that, slow down.... Rolling with laughter
Post #499629 Mon Jun 27 2016 3:31pm
Tyrefitter
Alignment is out,,I have 22's on my sport & ive done 8000 miles on them & they all have 6mm of tread left & wearing even.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #499631 Mon Jun 27 2016 3:35pm
Fletcher
Off track a bit , I bought a car many years ago that was sold to me as needing a problem sorting wth the clutch. It wasn't the clutch that was causing the judder , it was all four tyres were at 22 psi not 2.2 bar.
Something that is definitely underestimated and not checked as often as needs be in the motor trade .
Post #499639 Mon Jun 27 2016 4:05pm
fkarim
Which tyres have you got? I remember people used to complain about Continental tyres on L320 wearing at edges/feathering. It was classed as another "characteristic". Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #499643 Mon Jun 27 2016 4:29pm
udash
Thanks for the replies,
tyre pressures are correct and Tyres are 21 Conti.
Dealer had a another look and agreed that something is not right, and said that wheel geometry is correct so they have sent a technical query to LR so lets wait and see.
I do use the dynamic mode frequently but not at excessive speeds.
Post #499645 Mon Jun 27 2016 4:41pm
My L320 TDV8 has feathered the front tyres since I bought it 5 years ago. Done it on 20in and 19in tyres. I think there's an inherent issue with the air suspension. The air suspension system allows a large tolerance in ride height on any given wheel. Ride height changes affect camber (although not toe it seems from experiments on the ramp) and changes in camber will affect tyre wear. We set the car to tight tolerance for the alignment and then normal tolerance for usual use.
I've had alignments done and even when all of the settings were at or very near ideal settings, it still wears the front shoulders. The N/S/F is the worst. Most of my mileage these days is on dual carriageways so it's not fast cornering that's accounting for it. Elsewhere I don't drive like an 18 year old anymore so I'm not sure it's fast driving per se either.
I keep meaning to try a new air suspension module having had new height sensors and valve blocks all round previously. 2012 SDV6 - it's missing a couple of cylinders
Post #499657 Mon Jun 27 2016 6:09pm
Johnski
May I ask what type of four wheel alignment you have had?
I ask because there is different types of systems in use and those available in most tyre fitters are not suitable for our RRS cars. The cheaper ones with a very quick mirror on each wheel two minute sort are a real No No. (Not the women's shaver Very Happy ).
There is generally the only one system recommended for our cars and it can make a big difference to the result and that is the Hunter Alignment Systems (Hawkeye elite) many LR dealerships have different but often advise to use this companies equipment.
Other readers may feel differently and had better service elsewhere, I respect those comments and only advising from Professional reviews of tracking systems. John
Post #499674 Mon Jun 27 2016 9:01pm
It's the Hunter system Thumbs Up
My local LR dealership used Dunlop gauges on my RRS after fitting a new steering rack. I kid you not. And this was only after I queried why there was no alignment check done at all. Apparently their alignment bay had one of the technician's car on the ramp in bits and they couldn't use it. Suffice to say I don't go there anymore. 2012 SDV6 - it's missing a couple of cylinders
Post #499686 Mon Jun 27 2016 10:30pm
udash
I was thinking that that different suspension heights must be having a impact on the tyre wear, but ours stay at one height during all on road driving.
cars that lower the suspension height at faster speeds to improve the aero dynamics must be having this issue a lot as lowering basically change most of suspension values.
This is the report I got when they did it first time, report itself docent say if its a hunters system of something else
Post #499713 Tue Jun 28 2016 8:47am
