Home > General > ctek mxs5.0
Page 4 of 4 <1234
Johnski
The reason I wanted/needed one, (I have the 7.0) is because even though I have a good battery,
For some reason with the short runs and trips abroad for up to 20 days, I arrive back at airport to a flat battery. Censored
I didn't realise the drain caused by alarm monitoring, tracker etc would run it down. I have had LR check the battery, and they have confirmed it is fine, and said due to type of use, it either needs a permanent trickle charge or a full charge every 4-5 days. They did say they could fit LR version of this. Laughing
Not sure if this is correct, and didn't expect security systems to run battery down, but anyway that's why I have mine.
Anyone else had problems with airport parking drain and short runs? I also of course do long runs as well (this last year 16000 miles). John
Post #499618 Mon Jun 27 2016 1:16pm
I know jaguar used to make them last 28 days without a tracker.
You would want at least 14 days for a holiday.
It maybe worth you getting a big solar charger for use at the airport.
It won't be perfect but should help.
Post #499623 Mon Jun 27 2016 1:50pm
Tim in Scotland
Does your RRS have a socket that remains live with the ignition off? My 2007MY TDv8 and 2005MY 2.7TDV6 both had auxiliary sockets that stayed on after the key was removed, my 2015MY doesn't Big Cry .
If they do then I can highly recommend the £9.99 Maplin solar panel battery trickle charger. It has a blocking diode so the panel will not flatten the battery at night too. It plugs into the city lighter or auxiliary socket and charges the battery through that, just leave the panel below the sunroof if you have one or on top of the dash where it will get daylight on it. Mine even used to charge the battery of my FFRR when the car was covered in snow as these panels need only a small amount of daylight to work. It is only since 2011 when smart alternators came into use that I started to have battery problems and the cars since have not had a live socket when the ignition is off - they have all also had the press button starter, in case that has any bearing on it, previous cars all had an old fashioned key start. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #499630 Mon Jun 27 2016 3:32pm
There is a mod to make the fag lighter sockets live on the early models. (bypass the relay basically)
Post #499650 Mon Jun 27 2016 5:40pm
fkarim
That mod is how I did it in my L320 Black Edition - was connecting the CTEK to the socket in the boot. Sockets in L494 can also be made perm live similarly and that was the set up I was originally using for my CTEK. See step 11 in this write up to bypass the relay and make rear sockets live all the time: http://www.rrsport.co.uk/forum/post473608.html#473608 The guide is slightly unrelated (hardwiring a dash cam) but I just did the relay/socket mod while at it. Since then I have hardwired a comfort connector in the fuse box and undone the mod. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #499661 Mon Jun 27 2016 7:49pm
Page 4 of 4 <1234
