Home > General > ctek mxs5.0
Page 2 of 4 <1234>
This is good value.
M8 and slightly longer lead.
http://www.ebay.co.uk/itm/131604399133?_tr...EBIDX%3AIT
Post #485467 Fri Jan 22 2016 3:21pm
Wayneclarke
ok guys so i just checked if i have tow bar electrics and all i have is a single 7 pin black plug ??? is this what i need ??
Post #485513 Sat Jan 23 2016 9:41am
DrRob
Unfortunately not. Has to be 13pin or the grey 7pin
http://www.disco3.co.uk/shop/tow-electrics...c-p45.html * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #485515 Sat Jan 23 2016 9:54am
Wayneclarke
yeah had a funny feeling it would be to good to be true ,so just have to fit the comfort lead then. how did you fit yours if you don't mind me asking ?
Post #485516 Sat Jan 23 2016 9:58am
If the cigar lighters function with the ignition off, then you could buy a lead to connect into that.
or the power socket in the boot.
or you just connect it straight to the battery terminals with that comfort lead with M8 eyelets
Does the link to ebay I posted work for you?
Post #485520 Sat Jan 23 2016 10:38am
Wayneclarke
I did buy the cig lighter connector but been told the sockets all shut down when the car goes to sleep, the connector that came with it has m6 eyelets do these not fit ?
Post #485531 Sat Jan 23 2016 11:35am
Does the socket in the boot also shut off ?
I've read on here that M8 is the size for the RR. I've not tried a M6. Give it a go!
If it don't fit, all you need to do is file the eyelet out a little.
Once you have it working, let me know if you want to sell your cigar adaptor.
Post #485539 Sat Jan 23 2016 2:05pm
Wayneclarke
Ok mate I will do
Post #485541 Sat Jan 23 2016 2:51pm
JanRRS
United Kingdom 2013 Range Rover Sport SDV6 HSE Stornoway Grey
Re: ctek mxs5.0
Wayneclarke wrote:
just bought a Ctek 5.0 to keep my battery topped up through the winter as i do short journeys during the week, my question is with the charger i bought the cigarette lighter connector to charge through!! is this ok or should i connect a different way ??
Hello, I want to connect my Ctek 5.0 directly to the battery using the comfort connector ... Has anyone done this? As I am yet not too familiar with my new RRS, am I correct in assuming that the battery is under the spare wheel in the back?
Thanks
Post #499445 Sat Jun 25 2016 8:17am
JOCK55
United Kingdom 2013 Range Rover Sport SDV6 HSE Firenze Red
Hi, I assume you are referring to an L494 when you say "new" HSE. No model designation in your profile. This really helps when you are requiring assistance or information.
You are correct that both your batteries are in the boot. The main battery is beneath the spare wheel and the auxiliary battery (often mistakenly called the "stop/start" battery) is located behind the bulkhead on the offside of your load compartment.
In the engine compartment there are 2 battery terminals for charging/jump start facility. The positive (+) terminal is inside its own little plastic box to prevent shorting. Lift the lid of the box and the terminal post is visible.
Best connect a charger either using these terminals or via one of the plug sockets mentioned above. Whichever is most convenient.
Hope this helps.
Old Jock 2018 (MY19) Jaguar F-Pace R-Sport 300PS Petrol in Caesium Blue with many bells and whistles.
2015 RRS HSE SDV6 Firenze Red with Santorini Panoramic Glass Roof, gone but not forgotten.
Post #499455 Sat Jun 25 2016 10:08am
JanRRS
Thank you Jock. Thumbs Up
Yes, it is the L494, built in May 2016, delivered last week. HSE 3.0 SDV6 Dynamic.
Are those terminals easily accessible, i.e. can I just use the small Ctek clamps, or should I just wire the comfort extension connection to those terminals?
What I am trying to do is to have a quick and easy plug & play for the Ctek, and thought the cigar lighter sockets would do the job ... As those are not life, I was thinking of hard wiring the one in the boot. I did the same with my BMW and worked perfectly: plug in the cigar lighter, leave the Ctek in the boot, and close everything safely ... But if the terminals are in the bonnet, and easily accessible, I could do the same, leaving the comfort connector somewhere in the bonnet.
Do you know if the L949 has a live cigar lighter somewhere? I recall the Defender did ...
Post #499458 Sat Jun 25 2016 10:20am
JOCK55
Personally I just use the crocodile clips that came with the CTEK charger direct to the terminal posts in the engine compartment because it is convenient for me and the arrangement of the power sockets in the barn where I keep the car.
None of the cigarette lighter sockets are live from the factory, although my dealer did volunteer to make one permanently live if I required it. Must be a very simple job as there was no mention of a price for doing this (most unusual for a LR dealer)!!
Regards,
Post #499459 Sat Jun 25 2016 10:27am
JanRRS
Thanks Jock.
So that I get things right, to recap: I will use the clamps/crocodile clips on the terminal posts in the bonnet ... As I haven't opened the bonnet yet, is the terminal post easily visible? Where precisely? Any chance you can post a picture, obviously when convenient to you.
Alternatively, can you just tell me if there is a color, or a specific engine part... Or something that allows me to locate at first sight?
Post #499461 Sat Jun 25 2016 10:35am
JanRRS
Regards,
Old Jock
Thanks Jock. Terminal posts found, and Ctek running! Thumbs Up
Jan
Post #499475 Sat Jun 25 2016 3:18pm
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I recently bought a CTEC 5 charger. I have a 2011 RRS so can I connect the comfort wire to the battery and us that?
Post #499551 Sun Jun 26 2016 7:31pm
Page 2 of 4 <1234>
