| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > UNBELEIVABLE |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | Can you return the vehicle as unroadworthy to the seller? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Sun Jun 26 2016 1:09pm |
| Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203      | Hi Tim, I'm pretty sure that will be a no no mate as it was private sale, every time I remove something it's getting worse and worse. I'm   | ||
|  Sun Jun 26 2016 1:16pm |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407      | As Tim says, if purchased through a dealer, you would have grounds to return car under the sale of goods act, but he would have to be given the opportunity to fully repair first I believe, if a used vehicle.
| Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203      | Yes very true about re connecting, will give previous owner a call see what he says. | ||
|  Sun Jun 26 2016 1:18pm |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407      | I posted above at same time as the reply.   | ||
|  Sun Jun 26 2016 1:21pm |
| Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203      | I really don't like going to car traders because you can't even trust them, (no that's not completely true trust SOME NOT ALL) now days they charge you extra and also no what faults are hiding but like you say I surpose it's worth the extra for this exact reason, you can return within given time BY LAW, I've phoned seller and as I expected sorry it was ok when I had it  blah blah,
|  Sun Jun 26 2016 3:22pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | So the "private" seller has knowingly sold the car with faults that could have killed you? How many previous owners has the car had and when was the MOT issued because if it was only recently issued then it was done fraudulently as the airbags system wasn't working................   No consolation to you but I know a member of FullFatRR forums who went through similar problems with a FFRR, he took it to the local LR Indie who showed that every warning light on the dash was illuminated best you couldn't see them as the covers had been painted black.............. He had ABS, Stablity Control,Airbags and Engine Management lights on but couldn't see them for the paint 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Sun Jun 26 2016 4:09pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155      | Can't really make out cable colours, are they by any chance Red/Yellow, Red, Red/Green and Red/Black? the second colour being the tracer colour.
|  Sun Jun 26 2016 5:22pm |
| Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203      | Hi col, from memory I think they are the colours you specified, it's 1 off the plugs that go into the left hand side of the clock spring, yellow plug with 4 wires. All been cut about half inch from connector. | ||
|  Sun Jun 26 2016 5:29pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155      | Hi,
|  Sun Jun 26 2016 5:36pm |
| Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203      | Ahh so that maybe the reason for airbag light on, iv probably done 100/150 miles since purchase Friday evening, if previous owner had light reset can it take couple days to find fault again, I took all the bodged tape of & took picture of the 4 wires cut from wiring loom and they are linked 2 by 2 on a fuse loop (if that makes sense)
|  Sun Jun 26 2016 5:54pm |
|  Sun Jun 26 2016 6:08pm |
| Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203      | Yes Ill be on the phone first thing in morning trying to get it booked into garage for code reading and good look, now I'm thinking shall I re join wires before code reading so reader gets correct reading or leave it and let garage investigate before I do anything els.   | ||
|  Sun Jun 26 2016 6:23pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155      | Unfortunately I think it may be one of those instances where it will have to be reconnected to find the fault, hopefully the car will still have the original fault logged though. You may not have any redress from previous owner but perhaps he could at least tell you the original issue assuming he knew it had been done of course.
|  Sun Jun 26 2016 6:40pm |
| Posting Rules
 Disgusted I shall be giving seller a call and piece of my mind. .
 Or I'll
  Or I'll
 Thanks for all feedback and help really means a lot to have input/feedback/help/advice.
