![]() | Home > Maintenance & Modifications > Random alarm not bonnet switch |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5143
You could try pressing the lock button on the key twice.
| Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203
Thanks Andy, will give that a go, probably won't find out until stupid o,clock in the morning if/when it decides to go off. |
Yes its not very helpful but something easy in the absence of other idea's.
Yes, I'm seriously thinking of investing in a IID tool because from what I've read it's always good to have & I want to re calibrate and slightly lower ride hight, it's at 200mm at each corner but it's just a bit to high for me. |
Yeah I have an IID BT. Paid £400.
| Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054
http://www.rrsport.co.uk/forum/topic43444.html?highlight=bonnet
Hi puff, thanks for the link, when I went to investigate after alarm went off the sensor connector had already been removed and short circuit had been done so shouldn't that mean if alarm goes off after short circuit process it's not the bonnet sensor, I've taken sensor off anyways and give it a good clean and refitted the electrical plug so see what happens. 👍 |
| All times are GMT |
