![]() | Home > Faults & Fixes > RRS 2008 HSE 2.7 problem after problem |
Welcome to the forum David, that's certainly an unhappy post.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
I would also suggest that you get the rear callipers looked at as they can seize/part seize, which causes excessive and/or uneven wear. I've had both mine replaced in the last 2 years, one after chewing through a new disc |
SH0X Member Since: 25 Jan 2016 Location: London Posts: 82 ![]() ![]() ![]() |
Sounds a horrible experience and no doubt tainting your range rover experience but look on the bright side alot of this stuff can be sorted easily and cost effectively and yput get great support and info on the forums... being an ex mercedes owner I can say more so with the land rovers than the mercs...
David B Member Since: 22 Jun 2016 Location: Dunfermline Posts: 3 ![]() ![]() ![]() |
Thanks for the suggestions/replies, All work done now with no expense spared;
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4502 ![]() ![]() ![]() |
Brace yourself for an oil pump, as you have an 08MY |
