![]() | Home > Maintenance & Modifications > ABS pump comes on by itself |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003
Any fault codes logged, you don't always get a light on the dash. 2008 G4 RRSport TDV8 current
Could be steering angle sensor or abs sensor. Does the dsc light come on the dash? Bodsys Brake Bible
| shortty Member Since: 26 May 2016 Location: West Midlands Posts: 8
No fault codes and no flashing light. |
Are you sure it's the abs? The dsc light should come on when it activates. Bodsys Brake Bible
sounds just like the abs pump, but not applying the brakes |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9158
Torque converter? 2012 SDV6 - it's missing a couple of cylinders
Is the HDC button pressed in by any chance? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149
Check your tyre pressures as silly as that sounds.
| All times are GMT |
