Home > Faults & Fixes > front and rear parking sensors not working
Paszko
2005 Range Rover Sport TDV6 HSE Siberian Silver
hi, can any one help?
my front and rear parking sensors have decided to stop working, I get the annoying fault beep when in reverse or drive. it is coming from the rear and not the front.
I have tried the trick to locate a faulty sensor, however non are clicking. Ive also had a mate use his diagnostic machine and this has thrown up the below fault codes:
B1B57 front sensors power circuit
B1B58 rear sensors power circuit
after rearing the numerous posts, I can see that anyone has actually answered the question. Im thinking maybe a split wire on the rear loom....
any advice would be greatly appreciated.
Post #426457 Fri Jun 06 2014 7:03pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Seems to be an easy to happen thing, check the front bumper wires first as they seem to show water is an issue in there on the cables just find and patch em. worst case buy a new sensor. But they are not expensive.
Post #426593 Sun Jun 08 2014 10:44pm
robbietdv8
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
hey i have the same fault with my 2007 sport , checked all the sensors none tick, light on dash flashes.get a beep from rear when in reverse
cant see any broken wires but get the same fault codes as you.
i hoping you may be able to pass some wisdom on about what to do next the mrs is going on and on about getting them fixed.
thanks in advance
Post #463029 Wed May 27 2015 5:49pm
Paszko
Hi, still searching! Haven't had the time to take off the bumper to check.
Let me know if you find anything lol
Post #463030 Wed May 27 2015 5:56pm
robbietdv8
you got it Rolling with laughter 2007 HSE sport, grey on black 20inch black alloys.
My Range Rover and my Mrs are the same, both look great, both ride great and both love to give me hassles
Post #463031 Wed May 27 2015 6:03pm
seankenyon
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
Ive got the same problem and fault codes diagnosed on my Hawkeye diagnostics, took me less than half an hour to take the front bumper off, checked all the wiring and connections with no signs of water ingress or broken wires, even used a Decibel App on my phone with ignition to position one and the gear in drive & reverse and checked all PDC Sensors but its not obvious if they are working or not, difficult to hear if there is any clicking
This problem must be able to be sorted somehow?
Post #463166 Fri May 29 2015 9:43am
seankenyon
I managed to fix the problem, ordered a used PDC Module from America £45 Inc postage
Only difference was the part number, I got a YWC500550 and what I removed was a YWC500313
I don't know what the difference is but I read that it should be YWC500550
Anyway problem sorted, but bear in mind I also replaced a corroded loom and sensors first
Post #468854 Tue Jul 28 2015 6:35pm
goolraul
Canada 2007 Range Rover Sport 4.4 V8 HSE Java Black
have the same codes for front and rear sensors.
pdc light flashes and tone from rear sounder as soon as ignition is on
no ticking noise from any sensors. Replaced the module ($$$ )
still nothing. Big Cry
where is the loom usually broken/corroded? is it a ground or pwr wire?
help please!!!!!
Post #481607 Fri Dec 04 2015 3:39am
seankenyon
I replaced the rear loom as it was corroded in a few spots behind the bumper, only accessible by taking the bumper off, the rear bumper is easier to remove than the front
Post #481612 Fri Dec 04 2015 8:43am
goolraul
I'll have a look at the rear loom this weekend 😊
Thanks
Post #481619 Fri Dec 04 2015 10:25am
Had this issue and same codes on our D4, yesterday in fact.
Bumpers off, wiring checked (no issues), all contacts cleaned and greased appropriately.
System reset, no codes present. Works like a charm now.
Seems like ours could have been water/dirt ingress throwing the whole lot out. ON THE WAY: BMW F21 M140i
Post #481638 Fri Dec 04 2015 1:42pm
goolraul
Thanks for the input I wil let you know what I find....
Post #481643 Fri Dec 04 2015 1:54pm
goolraul
After a long winter i spent the weekend pulling both the front and rear bumpers. wiring is in tact and did a resistance check on every wire to double check. found nothing Crying or Very sad
checked for voltage going to front and rear harness and no voltage found.
Has any one been able to figure this out?
Post #493664 Sun Apr 17 2016 3:58am
Johnsurrey
Hi , Iv got the same problem , replaced the rear loom made no difference maybe the moduel next ? Or would it be worth doing the front first ?
Post #499110 Mon Jun 20 2016 10:06pm
