![]() | Home > General > 2007 RRS 4.2 super charged |
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
There is an emergency key slot in the passenger door handle under the cover.
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5137
Try unplugging the bonnet switch.
| bagsport Member Since: 17 Jun 2016 Location: essex Posts: 3
Thanks all, will try the sensor myself. Irritatingly I now have had a reduced engine performance message and engine going in to limo mode, turn off and on and works again. I've read it may be super charger pump, how easy a fix is that or is it one one the garage? |
| xanda Member Since: 01 Feb 2016 Location: Coleshill Posts: 11
I had the reduced performance. Very easy DIY fix to switch the wiring around, there is a tutorial on here somewhere. That said I would recommend getting it replaced and the wire switched at the same time. It's probably been running backwards for almost 10 years |
