Home > Wheels & Tyres > 275/40/20 on front and 275/45/20 on rear??
uu__26
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Buckingham Blue
So... this might be a pretty daft thing to ask...
But..
Recently bought 06 4.4 and it's got SC alloys, currently got 275/40/20's on all 4 wheels...
Had it serviced yesterday and they recommended replacing the two rear tyres, as cords exposed, which I already knew as it was mentioned on the most recent MOT.
Having read the posts here, seems to be recommended to upsize to the 275/45/20's for better ride etc...
Now he's the dilemma, the two front wheels are only 4 months old, so any issues with putting two 275/45/20's on the rear two and leaving the 275/40/20's on the front?? Or just swap out all 4??
Post #498937 Sat Jun 18 2016 12:18pm
You need to Run Either 45 or 40 profile all round Not Both, personally I prefer 45 profile bit better ride and slightly more rim protection.
Post #498941 Sat Jun 18 2016 12:37pm
uu__26
Thanks for confirming!!
I think as the front two are so new, I'll just put 40's on the rear, then have a look at it again next time!
Cheers!
Post #498943 Sat Jun 18 2016 12:48pm
Your centre diff won't be happy if you run different sizes front and rear.
Struggling to understand why you ran the vehicle with exposed tyre cords... Shocked 2012 SDV6 - it's missing a couple of cylinders
Post #498947 Sat Jun 18 2016 2:11pm
uu__26
MOT in May said...
n/s rear tyre inner side wall very deep cut, but no cords exposed
o/s rear tyre tread worn and going bald on inner edge
Got air con topped up on Wednesday and they didn't mention anything, and they are normally the first to try and get new tyres on there, but the LR were pushing to get two rears on there saying cords exposed, but I can't see anything...
Post #498950 Sat Jun 18 2016 2:19pm
uu__26
Ah.. just read the health check report again...
OSR Outer 5 Middle 5 Inner 0
NSR Outer 5 Middle 5 Inner 0
Both rear tyres bald on indder edges close to exposing cords
nsr has cut on rear wall that exposes cords
Post #498951 Sat Jun 18 2016 2:22pm
Just re-read this post, if your rear tyres are worn as you say Outer edge 5mm, Centre 5mm and Inside edge Bald, as there are normally only around 8mm on a new tyre I think you have a serious Suspension/Alignment Issue somewhere. I would suggest you also have a 4 wheel Alignment check done as well or new tyres may well go the same way.
Post #498970 Sat Jun 18 2016 10:50pm
uu__26
Yeah, got it booked in for 2 new rears and a hunter hawkeye alignment, but if not that it might be the bushes maybe?
Post #498971 Sat Jun 18 2016 10:54pm
One would like to think if it was only MOT'd in May there shouldn't be any excessive wear in the Bushes or this would have been at least an Advisory as well.
Post #498972 Sat Jun 18 2016 11:02pm
uu__26
Didn't find excessive movement in mot or service on Friday, so hopefully just alignment issue!
Post #498988 Sun Jun 19 2016 10:19am
uu__26
So....
I had the two tyres replaced on Wednesday, I wouldn't normally use Kwik Fit, but they had a really good deal of Pirelli which ended up being £110 a tyre, so suffered it, also they are the only place locally with a Hunter Hawkeye machine, I've checked Alignmycar.com and the nearest is 20 miles away.
Anyway, tyres were fitted all OK, and then the alignment started, first bit of grief was that they said what I'd booked online was just for the front wheels, I said just wanted the rear wheels done, so they said no problem. Chap came in to give me the keys and said the front had been sorted, but they couldn't adjust the rear, as the rod was too tight, and recommended I go back to LR to get loosened, as they didn't want to damage etc!! At that point, having read all of the stuff on here, I justed wanted my keys back and for them not to play around with it anymore. I called Kwik Fit Customer Service on way home and got a full refund, so no drama. BUT, I called LR today to book in for Wheel Alignment, and told them the story, and the said "Oh, well we can do it, but we don't have the equipment here, so Kwik Fit do all our alignments for us."!!!
Just thought I'd share!
Post #499995 Fri Jul 01 2016 11:57am
To be honest I think there was a clue in 4 wheel Alignment Check, personally I wouldn't use Kwik Fit to even check my tyre pressures.
Post #500000 Fri Jul 01 2016 1:41pm
I'd drive the 20 miles to get it aligned properly:thumbsup: , assuming that the one 20 miles away isn't a qwikfit also Laughing ON THE WAY: BMW F21 M140i
Post #500004 Fri Jul 01 2016 1:58pm
uu__26
Yeah, looks like a plan, just can't believe that LR dealer outsource to kwik-fit under their name...
Post #500006 Fri Jul 01 2016 2:20pm
