![]() | Home > My Range Rover Sport > Rear badge upgrade |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
Looks better up there |
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 ![]() ![]() ![]() |
Just ordered some to do the same |
johnharte Member Since: 21 May 2016 Location: Sydney Posts: 17 ![]() ![]() ![]() |
I did mine also:
Dave_telford Member Since: 15 Feb 2016 Location: Shropshire Posts: 22 ![]() ![]() ![]() |
For what it's worth, I've done badge stuff on 3 cars and this is how I've done it.
mcox42 Member Since: 10 Jun 2016 Location: Rugby Posts: 15 ![]() ![]() ![]() |
Thanks Tom. Hot water, bubbles and elbow grease it is then.
MM4747 Member Since: 22 Sep 2014 Location: Javea/Xabia Posts: 14 ![]() ![]() ![]() |
Hi Martin, one other thing to bear in mind. Before removing the badges clean all around and behind the old badges as grit gets trapped there and could cause scratches when removing them. A soft brush with soapy water is ideal.
The easiest way to remove the badges on the exterior is with a hairdryer and a length of dental floss to act as a cutter for the softened adhesive. Removing the badges on the interior is more difficult, especially the one on the steering wheel boss. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
I have done this on several occasions and simply used a kettle of boiling water, and brake cleaner to remove remaining adhesive and clean the surface.
eugeneville Member Since: 16 Apr 2015 Location: Fleet Hampshire Posts: 33 ![]() ![]() |
Definitely looks better up top |
