Home > Faults & Fixes > Parking sensors 2007 rrs
Johnsurrey
Front and rear parking sensors packed up continuous tone when starting up and button flashing
Diognostics saying front sensors power circuit and the same for the rear
All fuses under the bonnet and in the glove box ok
Any ideas ?
Post #498366 Fri Jun 10 2016 8:28am
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Corroded wiring loom more than likely.
Have you physically listened in to your sensors to see if any of them are clicking? to make sure its not an individuale one that's blown causing a short?
About 18 months ago my rears packed in and when taken to the dealership it was the fault of the wiring loom so it was all replaced. Then a few months back my fronts were faulting out ( which deactivates all of them) it was very intermittent but eventually i listened and could hear the front driver side corner not clicking like the others, upon removal of this, it's internals had completely fell apart causing shorts. Since i replaced this all has been fine.
Post #498548 Mon Jun 13 2016 6:51am
Johnsurrey
I've had a listen and rested my finger on all of them and none of them seem to be doing anything , looks like I'll have to take it to a dealership
Post #498550 Mon Jun 13 2016 10:43am
Danv8
Sounds like oit could definitely be wiring loom, If you confident in removing your own bumpers (plenty of guides) you could replace it yourself, To supply and replace my rear loom was just under £400.
Or take it to an auto electrician, who could trace the wires and just repair the broken wire.
Post #498787 Thu Jun 16 2016 9:19am
Johnsurrey
I've ordered and picking up a loom today from Harwoods so will sort it out at the weekend
Cost wise £70 odd plus vat
Post #498792 Thu Jun 16 2016 10:36am
Jacket2122
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Can anyone tell me what the part number for the front loom is?
Thanks in advance
Post #498826 Thu Jun 16 2016 5:56pm
YMQ501631
Post #498831 Thu Jun 16 2016 6:38pm
Jacket2122
Magic, thank you very much.
Post #498833 Thu Jun 16 2016 6:48pm
Johnsurrey
Replaced the loom tonight and it's still the bloody same !
Post #498839 Thu Jun 16 2016 7:57pm
Pufftmw
I gave up after pishing about with front rear looms/sensors & just removed the fuse under the glovebox.
Just park carefully now, like I've always done with cars/vans that don't have sensors, not an issue.
Post #499270 Thu Jun 23 2016 8:25am
CDS
What fault specific codes are to getting now? Over for a visit from disco3.co.uk
Post #499279 Thu Jun 23 2016 9:07am
Johnsurrey
B1b57-11 front sensors power circuit
B1b58-11 rear sensors power circuit
However I didn't get the fault codes cleared after I fitted the new rear loom , if that makes a difference
Post #499428 Fri Jun 24 2016 5:08pm
Johnsurrey
Had an auto Sparks have a look yesterday ( very reasonable price if anyone needs his number ) and turned out to be the parking ecu should of got him up first rather than buying a new rear loom .
All fitted tonight and working as it should
Post #500194 Tue Jul 05 2016 7:03pm
