![]() | Home > Technical > Rumbling noise from front deceleration |
Could be the front diff. When mine started to go the first manifestation was a noise on deceleration although more of a knocking noise than a rumble . 2008 MY Java Black TDV8 HSE
chopperchinn Member Since: 28 May 2016 Location: savoie Posts: 26 ![]() ![]() ![]() |
Thanks, this definately is a rumble/whirring |
As you don't say whether front or rear might be worth checking the rear prop centre bearing. 2008 G4 RRSport TDV8 current
Pretty sure it's coming from the front. Can't hear any outside noise but going to get it on a ramp at the local garage to see if we can determine the problem |
Danny1 Member Since: 25 Nov 2016 Location: Essex Posts: 61 ![]() ![]() ![]() |
Hi Chopperchinn,
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1546 ![]() ![]() ![]() |
I have the same rumbling from the front. It's been diagnosed as front diff and I have seen the quality of the oil from there which definitely shows that something's amiss. Just waiting for my Indie to schedule a slot to whip it out and have a look. Warranty job I hope.
Hi Eaters,
Hmm. Your problem sound very similar to mine. Vibration on the overrun. SWMBO doesn't notice it so its not massive but I do. First noticed it when I bought the car a year ago. Thought then that it was just what LRs do but a local 4x4 specialist took it for a test drive (about something else) and came back saying that the vibration was not right. They diagnosed a new front diff and prop-shaft (circa £2k from LR). They showed me oil from the front diff and it was awful. All grey/brown and you could feel bits in it. So there's definitely something wrong there. I had the oil changed as I was about to go on a long trip.
Hi Eaters,
Hi Danny
Hi Robin,
Just an update on this. I've now had the front diff replaced, and hey presto, the vibration has gone. |
Hi Eaters,
Hi Danny1
