Home > Maintenance & Modifications > "SUSPENSION FAULT - NORMAL HEIGHT ONLY" - After fr
sean2204
Morning all,
After having the front Brembo conversion done on Friday my car has seemingly developed an intermittent fault. It will occasionally read "Suspension Fault - Normal Height Only". Whilst this fault is active I cannot adjust the suspension height, however if I turn the car off then on the fault disappears.
I've searched the forums and it would seem the common problem would be the air compressor unit. So, just before I go and order one of these, could fitting the front Brembo's have caused this fault by knocking a sensor or similar? Or is it just purely coincidence.
Thank you
Sean
Post #497955 Mon Jun 06 2016 9:16am
I'd check the front height sensors first. 2012 SDV6 - it's missing a couple of cylinders
Post #497956 Mon Jun 06 2016 9:30am
chilly
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
check ride height sensors but i had this and was compressor as you say bt i didn't buy a new one i got a compressor refurbishment kit of the ebay cost me 70 quid rather than the few hundred quid
as lot of the time its just the filters clogged up and the moisture trap beads are saturated
took me brother about 2 hours to do for me only the dead truely know peace,
Bootneck its not a job its a way of life!
Post #498083 Tue Jun 07 2016 8:35am
