Home > Faults & Fixes > Amber Park brake light
Plazmapete
2 mornings last week I had the amber Park brake light come on. Could not release the park brake. Switched engine off for minute and tried again and It was fine. Any thorts? Thanks
Post #497905 Sun Jun 05 2016 6:00pm
Johnski
You don't say what model/year but.....The only thought that I had is that as yellow is a warning, get the codes checked (if you have something like the IID BT Tool no problems), could even be the battery, but may be needing "adjustment" Question
At least you can use your vehicle at the moment, just don't leave it parked in neutral. Wink John
Post #497922 Sun Jun 05 2016 9:42pm
May need the shoes adjusting or replacing. Might be a brake switch issue. Did it refuse to release when you tried to drive away or did you use the park brake switch to disengage (with foot on brake pedal)? 2012 SDV6 - it's missing a couple of cylinders
Post #497927 Sun Jun 05 2016 9:50pm
Plazmapete
Yes it would not let me move out of park. Until I switched engine off and back on again.
Post #497932 Sun Jun 05 2016 10:08pm
