Home > Technical > Bad Wheel Bearing?
toeuk1
Bad Wheel Bearing?
Hi all, I've recently had new discs and pads fitted to the front end. Also the NSF wheel bearing was replaced. Around 500 miles later, there is an intermittent squeal coming from the OSF area. It isn't there all the time and is audible up to about 35 mph. If you just touch the brakes lightly the noise goes.
The brakes have been removed, cleaned and copper grease applied - noise is still evident.
Indie wants £245 to change the OSF wheel bearing.
There is no play in the bearing and there is no vibration/rumbling whilst driving.
It sounds like there is a small bird tweeting away, could a wheel bearing squeal despite being mechanically sound?
Thanks.
Post #497890 Sun Jun 05 2016 2:25pm
Personally, initially I would try different make of pads before I started changing wheel bearings.
Post #497891 Sun Jun 05 2016 2:33pm
Tyrefitter
Sound like a brake problem.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #497892 Sun Jun 05 2016 3:02pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
Normally the bearing noise would get louder if you turn right (for left bearing) - open the window , turn at 20mph and see if the noise gets worse. I had bearing issue - making a clicking noise - but there was no play when you tried to pull the wheel - shop told me it was not the bearing - I had them replace it anyway - fixed the problem - but on your case - could be sticking caliper or other issue as well
Post #497949 Mon Jun 06 2016 12:56am
shakeapaw
put some copper slip on the back of the pads, worked for me 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #497975 Mon Jun 06 2016 12:33pm
Stecla
England 2010 Range Rover Sport TDV8 HSE Stornoway Grey
Warped brake disc might be the issue? 2010 TDV8
Post #498009 Mon Jun 06 2016 6:30pm
