Home > Maintenance & Modifications > New ARB bushes
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
New ARB bushes
After enduring the bumps and crashes for the last month or so; I finally booked my car in and got the bushes renewed. Apparently there has been some sort of design upgrade in the clamps but what ever they have done it has really transformed the handling of the car. It now feels really planted on the road and the steering is really sharp.
The only downside of having the work done is that the garage discovered oil weeping from a driveshaft seal...
Post #497191 Sat May 28 2016 8:46am
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Hi Salisburylander
How much were you charged for the ARB and where did you have the work done?
Post #497414 Mon May 30 2016 11:42pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
I was quoted £150 For new front bushes fitted to ARB with Ace system, By a indie in Hainalt Essex The body needs lifting to remove the brackets. I believe the non Ace system is easier, no body lift itisme
Post #497432 Tue May 31 2016 10:06am
Socast
Not sure where the rumour started but you don't need to lift the body to change the front ARB bushes, you do need to lift the diff slightly..
Post #497440 Tue May 31 2016 11:20am
Fish
Scotland 2007 Range Rover Sport TDV6 HSE Java Black
Front ARB bushes
With the assistance of a cut down socket welded to the ring end of a ring spanner (to get at the passenger side clamp bolts) all was done on the drive way with not too much of a problem other than a bit of spanner rash on the knuckles. No lifting diff, splitting drive shafts etc. Oh, and I have ACE fitted. Thumbs Up 2.7 HSE, Audi A6 Exec, Honda Accord Exec, Volvo 440, Volvo 360
Post #497447 Tue May 31 2016 12:13pm
ozzievechi
hi, what garage was it, Les Paul Motors? need to get mine done and 150 doesn't sound too steep. How long will it take to do?
Post #497454 Tue May 31 2016 1:02pm
Salisburylander
The work was done by an independent garage in Salisbury. The parts were £70 but I'm not sure about how much the cost was for just doing the ARB's as I had it serviced too.
Post #497469 Tue May 31 2016 3:31pm
jcw
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
Had mine done at James French including new drop links for just an hours labour, I supplied the parts.
Post #497592 Wed Jun 01 2016 7:22pm
