![]() | Home > Maintenance & Modifications > Front Camera's |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5096 ![]() ![]() ![]() |
Tony,
tonywolf Member Since: 14 Sep 2015 Location: Devon Posts: 97 ![]() ![]() ![]() |
Cheers Col, just took another look at the loose cables, PSB
Hi Tony,
Thanks Col, so when are you fitting your GTS kit? I managed to fix the loose lower grill and see why the OS fog lamp was loose. I need a new fog light as it was only secured by one lug |
Have made a start with the kit in so much as have Rear Bumper Fitted, just have to find time to do the Front now |
How was it easy? Must say if you ever had to deploy the spare wheel that would be a challenge due to that lower trim. But it is a good looking kit!! Best Regards
