Home > In Car Electronics > No sound
nozz
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
No sound
Hi all
radio has been working intermittent for a couple of days,now its gone off completely all appears to be fine but no sound
any ideas
Post #496549 Thu May 19 2016 9:09pm
Timf
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Is it still no go? I had the same. Overnight I left it & it came back Rolling Eyes
Post #496719 Sat May 21 2016 5:15pm
nozz
Yes mate it's still same tried disconnecting battery aswell,had it on diagnostics and it comes up with audio control module
Post #496728 Sat May 21 2016 8:42pm
dpg123
I understand this issue is linked to a static issue for which there was a Technical Service Bulletin. It's something to do with a voltage spike in the amp upon start up. I had this issue and spoke to Land Rover directly and they advised there is an official repair (a software update) which is free at your local dealer. I'd get in touch, check if yours has been updated and if not book it in.
Post #496982 Wed May 25 2016 10:11am
nozz
cheers,just phoned explained everything,they say theres no update,
Post #497007 Wed May 25 2016 6:00pm
Johnski
I've been told that before, but I had the number and details of update, I don't think they bother to look properly, as they miraculously then found it. Sad John
Post #497011 Wed May 25 2016 6:43pm
nozz
I'll see if I can find any more details of update
Post #497012 Wed May 25 2016 7:05pm
Johnski
Best of luck, otherwise ask the member if he has the details of what LR said it was if possible. John
Post #497026 Wed May 25 2016 10:01pm
dpg123
Hi again,
Speak to Land Rover customer care on 0370 5000 500. Make sure you have the reg no and VIN handy. Explain the fault, say you're aware of an update and ask them to check if they have a record of it being actioned on your vehicle. If not then you should be able to get it sorted for free. Some of the dealers only have limited access to the full LR technical systems...
Post #497053 Thu May 26 2016 8:53am
nozz
cheers ill try next week
Post #497221 Sat May 28 2016 8:21pm
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Another TSB but only for the US was LTB00179NAS2. Basically they state loss of audio with possible frozen touch screen on LR logo.
Problem is MOST related and a loss of communication within the system.
I can't upload the TSB here from the phone, but google the above and you should find it.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #497276 Sun May 29 2016 10:28am
nozz
found out what it is , its the red/orange wire that goes up to the display if i wiggle it radio comes straight on just need a way to keep it on
Post #499941 Thu Jun 30 2016 9:07pm
SH0X
When I took my screen and dvd unit out I saw there is an optical wire which need to be in and possibly clean also all wires in the back could do with removal and blow and insert same goes for wires in dvd unit under passenger seat.
This all works together and if there is a break or removal.of the optical wire it means no sound at all even though the radio will power up and function.
Hope this helps
Post #499966 Fri Jul 01 2016 3:32am
