Home > Maintenance & Modifications > Another Brembo caliper question... rear calipers
sean2204
First of all thank you for all the help so far and I apologise for yet another question... if anyone could help though I'd appreciate it.
Which calipers do I need for the rear conversion? Is it the same as the front ones? Is it the same for the discs?
Also does anyone have the part numbers for the dust covers front and rear?
Thank.you guys.
Post #496766 Sun May 22 2016 2:32pm
The RRS has tiny calipers at the rear. And generally they only fitted brembos on the fronts.
Consider if it is worth while fitting to the rears! And no, I would think they would be smaller. (certainly not 6 pots)
Post #496795 Sun May 22 2016 8:26pm
sean2204
Going for the all round conversion. Just need to know the correct parts
Post #496799 Sun May 22 2016 9:21pm
I didn't think L/R ever fitted Brembo Calipers to the Rear of the Sport unless they do on the SVR. My 5.0L S/C has the 6 pot on the Front but not Brembos on the Rear.
You may need to go to someone like JE Engineering who do Brembo GT Brake upgrade but it costs around 2.5k for the rears alone.
Post #496800 Sun May 22 2016 10:13pm
sean2204
Thanks Col. I'm assuming it has different rear brakes to my SDV6?
Post #496802 Sun May 22 2016 10:58pm
Lost for Words
Little point in going any bigger at the back because the grip just isn't there.
You will have the same rear calipers as all the rest - there are two sizes of caliper carrier (known as the V8 upgrade in D3 terms) with the larger fitted to all the Brembo/facelift models, so this upgrade may be applicable to you?
Remember, there's not much room at the back because of the EPB drum. Thumbs Up Visiting from DISCO3.CO.UK
Post #496807 Mon May 23 2016 9:29am
sean2204
Would these fit the rear of my SDV6..
http://www.ebay.co.uk/itm/161723864969?_tr...EBIDX%3AIT
Thank you
Sean
Post #496812 Mon May 23 2016 11:30am
