Home > General > Smart key
Camelrock
Smart key
We've got a face lift sport in and it says smart key battery low, we've replace the battery but the mes is still coming on, on start up. Have tried lock/unlocking the car etc but made no difference. Is there some reset or anything we need to do ? 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #496507 Thu May 19 2016 11:33am
ravingmad
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
When I replaced the battery in mine, the message stayed on for a few days and then went.
No idea behind the logic of it. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Driving a milk float for now.
Post #496511 Thu May 19 2016 12:06pm
Johnski
There was a advisory letter sent to all LR dealership about problems with batteries,
But that was due to people using a known good battery or a working battery from another key fob,
You must always use brand new, unused and from a sealed packet.
I'm not sure why this should make such a major problem, but there you are.
If you have. Used a brand new battery from a sealed pack, then I have no idea I'm afraid. Crying or Very sad John
Post #496521 Thu May 19 2016 2:24pm
Camelrock
Thanks for the replys will pass on to the powers that be and let them deside what they want to do Thumbs Up 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #496531 Thu May 19 2016 4:06pm
Tyrefitter
When I bought my sport last July both remotes were showing low battery & 2 weeks ago I got 2 new ones & the message went off straight away.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #496535 Thu May 19 2016 6:39pm
Brian
Scotland 2013 Range Rover Sport SDV6 HSE Stornoway Grey
Agree with Johnski. I put a brand new unbranded battery (multi pack kind) in and it still showed battery low. Replaced it with a brand new Duracell, out a sealed pack and the message went. Cheers
Brian
Owned: '13 HSE Black Edition 3.0 SDV6 Stornoway Grey
Gone: '57 HSE 3.6 TDV8, Zermatt Silver
Gone: '02 Discovery 2 TD5
Post #496569 Thu May 19 2016 11:29pm
Reference
SSM56277
Models Range Rover Sport / L320
Range Rover Evoque / L538
LR4 / L319
Range Rover / L322
Title 10my `Smart key battery low` message displayed in instrument pack message center
Category Electrical
Last modified 05-Apr-2012 00:00:00
Symptom 204000 Instrumentation
Content Vehicles affected, 10my Range Rover, Range Rover Sport, Discovery4/LR4
Issue
When the " Smart key battery low" message is displayed in the instrument pack message center dealers are complaining that after a replacement battery has been fitted the message does not disappear. The dealer then replaces the key in the belief that the key is faulty.
Cause
Dealers are swapping batteries from known good smart keys to diagnose battery low message or fitting aged batteries off the shelf. The message is displayed when the smart key voltage threshold has dropped below 2.44 volts. The message will clear if the smart key battery threshold is higher than 2.95 volts.
Note: these voltages are only measurable when the battery is inserted in the smart key.
Action
When the " Smart key battery low" message is displayed in the instrument pack message center dealer technicians and customers must fit a NEW still in the packet battery.
Under no circumstances should you swap batteries from a known "good" smart key.
LR part number is YWK10003L. (battery type CR2032)
Please note: CR2032 batteries stored in high humidity +75% & at high ambient temperatures greater then (+25degC) will greatly reduce its shelf life.
After replacement of the battery two smart key authentications need to take place to clear the message and to recognize the new battery voltage.
This is achieved by pressing any button on the smart key twice.
If the "Smart key battery low" message does not clear in the message center fit another new battery and retry.
If the "Smart key battery low" message is still present please replace the smart key, submit an EPQR and retain the smart key and all associated batteries for investigation. Please label the original battery and replaced battery separately.
Post #496571 Fri May 20 2016 5:22am
