![]() | Home > General (L494) > These wheels weigh a ton! |
I know. I have the full size 21" spare and removed it to look for the spare wheel lift assist strap (which I then found wasn't there). On that note, do you have that strap? It should be supplied FoC depending on your spare wheel size. I got it from my dealer later. Supposed to make the job of lifting it out easier.
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 ![]() ![]() |
Size and the weight of the wheel makes it almost a sure way of getting a back pain. Like Fkarim I got the strap tool free of charge as a service action, dealer said its only valid for 21 wheels. |
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 ![]() ![]() |
I had one in my car on delivery and I have 22" wheels? MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys. |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
No lifting strap with mine, apparently my puny 20" wheels don't need one.
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 873 ![]() ![]() |
I also changed my wheel on the week end. I wanted to fit the 20 inch blacks I had purchased but only one would fit #@@. I decided to put the spare on the front and boy is it heavy. I do have the strap , and I see no logic to it not being supplied to all wheels as the weight and outside diameter should be similar, smaller wheels run higher profile tires. Not supplying the lift strap is another sign of the petty cost saving Land Rover does for no good reason. As a first time new buyer of the brand I personally think Land Rover has a way to go if it wants to be considered for more than the oval badge.
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5642 ![]() ![]() |
I changed mine twice a year (winter/summer) so I know how heavy they are |
Calling LRA assist in outback Australia could mean you are dead by the time they arrive ! For that matter the nearest LRA, NRMA , could be a long wait in very hot conditions just for a flat.
Good point |
