![]() | Home > Faults & Fixes > The "Faults & Fixes" forum |
| Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662
Hi all,
Since the Discovery 3/4 and Range Rover Sport share so much of their architecture and engineering it is also worth checking the following links:
A little more information would be helpful, such as what age the car is, how many miles, what engine, does it do it all the time etc...
| Martinberry1 Member Since: 25 Apr 2013 Location: Dover Kent Posts: 6
Hi Micky sorry first time using this site the engine is 2.7tdv6 on a 55plate and has done 76500 and yes it dose it all the time if I'm rolling at low speed and push the throttle quickly 9 out of ten times it dose it can you help thanks martin |
| MR08ASH Member Since: 17 May 2016 Location: Wales Posts: 2
Hi guys it my first time on here. I also own one of these monsters. V8 3.6 2008. i will be posted pics so u can view. I wants to know where is the lower air con port so i can fill it up. Thanks guys waiting for reply. Hope to have a good communication with u all. |
| Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118
Take it to a Garage |
Take it to Halfords or kwikfit. Mine was completely empty. £49. Good price. |
| Cheryltyla Member Since: 27 Jun 2016 Location: Nottm Posts: 1
Hi.. My RRS 55plate 4.2 v8 supercharged is being a bit temperamental at the moment, I've had it just over a year and had no problems.. Been away for the weekend and whilst away it wouldn't lock or unlock, I was having to unlock/lock using the passenger door handle.. Got back to home town and was ok for a few times... This morning it's at it again.. Any ideas?? .. Thanks |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407
You shouldn't attempt to refill or charge Air Con systems, there are strict rules and laws on this, due I believe to release of hazardous gasses into atmosphere. This applied more to the old gas used in air con systems. People carrying this out have the proper equipment to drain and capture and refill your system, and add a dye if a leak is expected. If you have this equipment then I apologise. I believe (told read somewhere) you can purchase tins for DIY, but not ad visible as you can get severe burns and wouldn't wish injury to any members.
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Remember finding the ports once - think they are next to the battery on the inboard side; you'll have to take off the battery dust cover to see them. 2008 MY Java Black TDV8 HSE
