![]() | Home > Maintenance & Modifications > MY12 Overfinch - Should this have daytime running lights? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5139 ![]() ![]() ![]() |
This may help if it's legible.
sean2204 Member Since: 05 Mar 2016 Location: York Posts: 55 ![]() ![]() |
Thanks Col, I'll try this.
Tried the above and no joy so contacted overfinch...they want 240£ to investigate it!!! Blimey. |
Fixed this morning. 10amp fuse had blown. Replaced and both bumper LED and Angel eyes working as DRL. |
Down&Dirty Member Since: 31 Dec 2015 Location: Somewhere out back Posts: 92 ![]() ![]() |
Sean2204,
That would have been a Very Expensive Fuse had you taken it to Overfinch ![]() Cheers Col |
Tell me about it!!!
Great thanks |
higgsym Member Since: 11 Jul 2016 Location: bristol Posts: 1 ![]() ![]() ![]() |
having same issue with same setup? where did you find the fuse bud?? |
tonywolf Member Since: 14 Sep 2015 Location: Devon Posts: 97 ![]() ![]() ![]() |
On my OF, only the lower LEDs work as DRLs, which I thought were normal? Best Regards Tony MY2014 SDV6 AB Dynamic |
