![]() | Home > General > 2012 sport. Speedo Dial top dash pod, how to remove? |
thomas brown Member Since: 29 Mar 2016 Location: Norwich Posts: 559 ![]() ![]() ![]() |
Hi col.
Hi.
Ahh i see. Is it hard to remove the steering wheel?
It is quite easy to remove the Airbag but you will need to buy the tool to release it, if you go on to Powerful UK website they have videos how to do it. You will need to disconnect battery first and leave car for 15/20 mins. for system to discharge any residual current. Before you disconnect battery make sure you extend the steering wheel out towards you and lower it down as far as it will go to give yourself plenty of room as I imagine you have the electrical adjustable steering column.
Hi Col.
Believe me it makes it so much easier to remove everything with the wheel off and It only take a few minutes to take off..
I am Going to remove the wheel now as you say it makes it alot easier.
Thanks again though |
The tool you need is to release the Airbag not remove the Steering Wheel, just search Airbag Removal Tool on e-bay. As I said look on Powerful UK site the sell the tool and show a Video how to use it.
Thanks for the link col |
Watched the video, it looks pretty simple to be honest. Have looked on utube for the 2012 shape steering wheel removal but cant find one. Still im sure they are almost the same.
Hi all.
