![]() | Home > Wheels & Tyres > Does Offset Matter ? |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 750 ![]() ![]() ![]() |
Not really. Regards etc.,
SPX Member Since: 27 Dec 2012 Location: South Yorkshire Posts: 587 ![]() ![]() ![]() |
-4mm definitely not, +4mm sometimes can though if the brakes are very close to the wheel spokes. |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 873 ![]() ![]() |
I have purchased some 20 inch wheels to replace the useless 22 inch wheels which are just for show. I hope the 4 mm does not matter as I did not try the wheels on, they are the Genuine older model wheels . I did check the inside for load rating though. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Well I can tell you a slight difference in off Set does matter. The Front suspension will rub the tyre with 5 mm difference in offset. So be very care full. I have just fitted some OME RRS wheels with 53 off set and there is .5 of a mil between tyre and the suspension up right component on the front. My situation made a little worse by running 285/50 R20 Coopers. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
I've just fitted my 22's with 50 off set & 295/40r22's & their is about 5mm between tyre & strut.
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 ![]() |
Just put a 5mm spacer on spiteful Range Rover Sport tdv8 |
Can I ask where one would get a spacer from ? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Type 5mm wheel spacer in to ebay, there's gazillions of them spiteful Range Rover Sport tdv8 |
Anyone have the PCD to mind to save me finding it for the RRS? Did find 6mm spacers listed but am concerned if this will impact the amount of thread available for contact with the studs? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
German-wheels Member Since: 23 Jul 2016 Location: Bournemouth Posts: 88 ![]() ![]() ![]() |
RRS has PCD of 5x120, center bore of 72.6.
Thks for that I found the PCD , Looking at making some steel shims about 2mm , the tire rub is very light and I could probably leave as is but the low speed squeak makes the car sound cheap. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 ![]() ![]() |
I am looking to purchase some 22" x 10 Riviera wheels for my 2011 plate RRS, the offset is et30, I'm sure these will fit, but worried they will stick out too far!?
The way I understand off set your wheel would be moved out about 19 mm with a 30 off set? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Thehos Member Since: 24 Jul 2016 Location: Somerset Posts: 123 ![]() ![]() |
Same pcd and centre bore as bmw |
